Looking for a way to seamlessly connect your local and remote systems? Today, I’ll guide you through a simple, yet effective, method that harnesses the power of SSH and SFTP. You won’t even need tools like NFS or Samba.
Benefits of Using SSH and SFTP for Remote Folder Mounting
- Security: With SSH, you get encrypted communication.
- Simplicity: Avoid complex configurations of tools like Samba or NFS.
- Flexibility: Great for various use-cases where you need to access remote data as if it’s local.
Step-by-Step Guide to Mounting with SSHFS
- Installation: On an Ubuntu system (other distributions might slightly differ), start by installing
sshfs
. Ensure you have root privileges.
apt install sshfs
Basic Mounting: Here’s how to mount a remote folder quickly:
sshfs [email protected]:/home/sanglyb /mnt
Authentication Using Keys: If you’ve set up key-based authentication, use:
sshfs -o IdentityFile=~/.ssh/id_rsa [email protected]:/home/sanglyb /mnt
Custom SSH Ports: Using a non-standard SSH port? No problem!
sshfs -p 10022 -o IdentityFile=~/.ssh/id_rsa [email protected]:/home/sanglyb /mnt
Auto-mounting with SSHFS: Want the folder to mount automatically? Add this line to
/etc/fstab
sshfs#[email protected]:/home/sanglyb /mnt fuse defaults,idmap=user,port=22,allow_other,reconnect,_netdev,users,identityfile=/root/.ssh/id_rsa 0 0
Then, either reboot or run:
mount -a
Unmounting: To disconnect:
umount /mnt
Troubleshooting:
Encounter the “fuse: bad mount point `/mnt’: Transport endpoint is not connected” error? Resolve it with:
fusermount -u /mnt
Conclusion:
Mounting a remote folder using SSH and SFTP is a straightforward and secure method. Whether you’re a system admin or a tech enthusiast, this approach can make your operations efficient and hassle-free. Don’t forget to share this guide with friends or colleagues who might benefit!
